Ir para o conteúdo principal
Pequenas máquinas de café expresso automáticas da Melitta. Estes guias também podem ser úteis para outros modelos Melitta e máquinas de café expresso da Nivona, Siemens e Miele – os modelos possuem uma estrutura semelhante.
Selection button not responsive
The single cup serving button is not responsive, but the 2 cup button works ok.
Is this controlled by a micro switch?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
I did not do this repair until now, but I'm quite sure, there is a microswitch, which has to be replaced. Another possibility: replace the PCB. I found a used one for you at ebay.
Use this guide to open the Caffeo and have a look.
Esta resposta foi útil?
Pontuação 2
1 comentário:
The info was useful for disassembling but there is more work to do to release the front panel. It looks like the fault will be with the pcb/ display/ switch pack.
The link to the pcb/display controller on eBay do not post to the UK.
Thanks.
por Compartilhar
Don't they ship to UK?
Pontuação 2
1 comentário:
No they don’t ship to uk.
After looking at the inside of the machine after 2.5 years use, it looks well worn so I have decided to get a new one as I think there will be other problems ahead.
por Compartilhar
2.5 years - that's nothing! These devices live nearly forever, just like airplanes, if worn parts are replaced in time.
Another possibility: the service of Melitta itself is good and not too expensive.
Pontuação 1
Adicionar a sua resposta
Steven Mccluskey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 24
Ao todo: 419
