I cant pair my device
when I have to pair to the mobile phone. the light never starts to pulse. it only lights up green when I release the button
Esta é uma boa pergunta?
Hi Fredrik, did you use the nothing X app? If yes, did you use it to pair your devices together? The app (for no obvious reason) will need you to turn on your phone's location (and the bluetooth of course) in order to proceed to the pairing process. Once it's done, it'll ask you to leave the case open with the earphones still inside then keep the button pressed until the light blinks.
I'm pretty sure you've already been through all this but it was'nt mentionned on your message. I had trouble to pair it once, my right earphone was'nt showing through the app and I tried to forget it and pair it again using the app. I managed to get it working by forgetting it through the bluetooth menu of my phone after forgetting it on the app, then restart the pairing process.
Sorry for my english, not my native language. Hope it helped.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 1,626
It's on light don't worked
por Habt Ty
Hello! I also have the same problem. I cleaned them, restarted them and also updated the app and none of that worked. Note that when closing the box it does not reach the pressure of the magnet, could that be part of the problem?
por Amellali Pérez
