Ir para o conteúdo principal
Turn off itself occasionally.
My plasma TV tcp55st30 occasionally turn off itself. It clicked, screen went black and the power light stayed solid red. I unplug the TV for 5 minutes, plug it in power up and worked until the next black out.
Update (07/08/23)
Update (07/08/23)
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
Can you take the back off the TV and upload a picture of the circuit boards inside? Adicionar imagens a uma pergunta já existente
por
I'll do it over the weekend.Thanks.
por
Sorry to take it so long to upload these images.
por
Adicionar um comentário
1 resposta
@ahyong intermittent failures are the hardest to diagnose. Here is the way your TV is supposed to work (Turn ON)
IC8000 on the A board outputs the “TV_SUB_ON” command. The “TV_SUB_ON” command is provided to pin 5 of connector P6 of the power supply to develop the F15V. At this time, the relays on the power supply are triggered and a click” sound can be heard.
The F15V from the P board is applied to the Voltage regulators on the A board.
IC5000 outputs the "DCDCEN(ENABLE)" command to the voltage regulators to output several voltages respectively.
I know it's a lot of "blah blah blah" but that is the clicking you here. It sounds like it may be a component on the A-board which is failing (overheating). That would also explain why it works again after 5 minutes.
A-board is the bottom board in your last picture.
Esta resposta foi útil?
Pontuação 0
3 comentários:
Thanks. So I need a new or used A board. When watching certain channels, the pictures / screen become distorted. Is that the cause of overhead or bad A board?
por
@ahyong only on certain channels? Yes it can be but that is even harder to diagnose :-)
For now my prime suspect are the A-Board and the P-board. I'd go with the A-board first. This is not scientific, just a gut feeling. Get a replacement for as inexpensive as you can find. Used is okay because I do not want you to spend your hard earned money on my gut feeling.
por
Thanks again. I'll get an used A board and will update in the near future. THANKS again I really appreciate your time and input.
por
Adicionar a sua resposta
Ah yong será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 131
