Why is my laptop beeping continuously?
I tried to turn on my laptop and found my laptop beeping continuously.What should I do to fix it?
Esta é uma boa pergunta?
You should try checking with this HP guide. Your problem might vary from a dead CPU, to a simple reset. I've had similar issues with some Lenovo machines and the issues was solved with a simples reseat of the RAM. Good luck.
Esta resposta foi útil?
None of them helped
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 49
Ao todo: 570
4 comentários
Hello, are the beeps in a sequence by chance, or is it just one long beep? If it is a sequence if you could count the beeps and reply that would be great!
por BurtBen Compartilhar
No it's actually beeping like a car's blinker
por Jackson King Compartilhar
Could you possibly record it and add it to the post?
Not sure how?:
Adicionar imagens a uma pergunta já existente
The beeps could indicate a fault. The number of beeps, as BurtBen suggested a recording, might help us diagnose the issue.
How old is the laptop?
por JnCA Compartilhar
