Ir para o conteúdo principal
A linha de notebooks iBook da Apple foi destinada aos mercados consumidor e educacional. A linha iBook compreende o iBook G3 Clamshell, G3 12", G3 14", G4 12" e G4 14".
Fix a black screen
I want to remove the screen or disamble and replace screen
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@feliciajoh54232 sounds like a plan. What exact model is your iBook? That way we can try to assist you with the execution of your plan.
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
First, follow this nifty little tool to figure out what type of iBook you have. When you reach the end, it will show you what computer you have. Click it and it will take you to your computer's page. See if there is a guide for screen replacement. Hopefully (fingers crossed) there is. However, if there isn't a guide, you'll have to find one on the internet. If you have to do that, you might as well create a guide so others won't have to dig around to find help on replacing their screen.
Good luck!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Felicia Johnson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 209
