Ir para o conteúdo principal
Um mouse sem fio Marathon da Logitech lançado em 2010.
Fix Left click button
Left click don't work while all other buttons work properly
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Pergunta mais útil
Imad, when you press the left click button, does it still make a sound? If not, you probably either need to replace the switch (the mechanism that registers clicks) or buy a new mouse (if you don't want to disassemble your mouse), and if so, it's probably something a bit more complex, in which case I would heavily recommend buying a new mouse.
Esta resposta foi útil?
Pontuação 2
5 comentários:
Dear Shingle
Thank you for your quick reply.
Yes i still have a click sound ;what to do in this case?
por Compartilhar
@imadchidiac Well, that means that the switch isn't broken. What specifically are you using the mouse for? Also, how long have you been using it for?
por Compartilhar
I used for a smart TV less than a year
por Compartilhar
Hmm. And all the other mouse buttons work? That's quite strange. Have you tried using a different mouse? If left-clicking doesn't work with the different mouse, then it is a problem with your smart TV. If left-clicking does work with a different mouse, then you should probably just buy a new mouse. Personally, I would recommend the Logitech K400 Plus if you want a trackpad-keyboard combo, or either the Logitech M705 or M330 if you already have a keyboard (the M705 has better battery life, but is slightly more expesnsive, and both mice are on sale).
por Compartilhar
I have this issue and am willing to explore other options. The device is out of warranty, so I have nothing to lose. If it still makes a click sound, what are some things to investigate other than replacing the switch?
por Compartilhar
Maybe worth a try--what do you have to lose?
(I'd use electronic cleaner or 91/99% alcohol instead of WD40):
https://www.youtube.com/watch?v=-w-W6MAn...
Good luck!
Pontuação 0
Adicionar a sua resposta
Imad Chidiac será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 45
Ao todo: 2,887
