Philips HTB3520/94, POWER OFF AFTER 30 MIN.
My philips home theater model no. HTB3520/94 turns power off, no indicator, after 30 minutes...
Esta é uma boa pergunta?
@sunildeshmukh first check your settings to rule out that this is caused by the timer
Energy saving settings
Esta resposta foi útil?
It's power cut off power, no standby indicator, no light 🚦 indicator, it's off after 30 min or plus or minus 10 min. In working condition... Means it's power supply output to audio is correct but cut off may be heatsink not support...my opinion... Sleep mode what you said is not set by me... Or if it is working, then it should be working in ideal not in working means when my system is working or songs are playing continuously... Hope i tried to explain is right....
Pl correct me if I'm wrong...
Anyway thanks for your effort to read and provide me the solution... 🙏👍🏻😊
Meanwhile I replace the HTR of heatsink still problem remain same... It's power cut off after 30, 40min...
Pl. Suggest any other solution...
@sunildeshmukh That is good. At least we now know that this is not a settings issue. Let's see if we can determine what cuts the power. How long does it take before you can turn it back on? Few minutes or immediately?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 84
