Ir para o conteúdo principal
Informações de reparo e desmontagem do ROG Ally, um console portátil de jogos fabricado pela ASUS. Lançado em 2023 e identificado pelo número de modelo RC71L.
Screw list for ROG Ally
Hi guys, I'm looking for the list of screw using in the ROG Ally, specifically the middle short screw on the back panel. I unfortunately stripped it while replacing the SSD and looking to see where i can get a spare one
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
Have you been able to figure out the length?
por
Adicionar um comentário
2 respostas
The thread is M2, and the 5 long ones are M2 x 16, unfortunately, I don't know what the middle one is. I haven't had to replace that one. But it is an M2, just not sure what the length is, but if you can measure the length of the threads in mm (millimeters) than you have that number. Ex. M2x16 is thread pitch M2 x 16mm... Hope that helps.
Esta resposta foi útil?
Pontuação 0
2 comentários:
My three bottom screws can’t screw in. I don’t know what it’s called, but the gold things in the holes where the screw goes in came out.
por
I have the jsaux backplate. The gold things have come out of the front plate.
por
The screw sizes for the exterior shell are m2 x 16mm for the 5 screws around the edges and it's m2 x 10mm for the middle bottom screw. I stripped my center one, so I took some measurements to figure out what size it was
Pontuação 0
1 comentário:
Does anyone know the screw type for the joystick screws?
I lost one mid replacement of drifting joystick
por
Adicionar a sua resposta
Bui Dave será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 17
Últimos 30 dias: 98
Ao todo: 5,806
