Ir para o conteúdo principal
Guias de reparo e resolução de problemas para a série Presario CQ58. Estes são notebooks de baixo custo fabricados pela Compaq, que pertenceu à HP de 2002 a 2013.
Why is my computer so slow?
When i boot it up it will take a while to load and it take 2 min to load up the taskbar and it’s so slow at everything so can someone please help me???
I have tried to factory reset it and and get a lot of anti virus
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @jonathanm52184
What is the full model number of the laptop as shown on the information label on the bottom of the laptop?
How much ram is installed?
What OS (Win7, Win8.1, Win10) is installed?
Does the laptop have an SSD or a HDD installed for storage?
Your laptop is showing its age. Last version of a CQ58 laptop was released in 2013.
You can only improve performance so far by increasing the amount of ram (model number needs to be known though) and also if there's a HDD installed by upgrading to an SSD.
Other than that you may be limited as to what more you can do.
Depending on the exact model you may be able to upgrade the CPU but maybe not and then if it is a removable CPU and not hard mounted, the upgrade choices may be limited by the motherboard's chipset model and BIOS version as they may not be compatible.
Esta resposta foi útil?
Pontuação 1
7 comentários:
It has 2gig of ram win 10 has a hdd
por
@jonathanm52184
For best performance in Win 10 you need at least 8GB of ram or more, but the full model number needs to be known to find out if it can be upgraded successfully or not
por
There is no labal
por
@jonathanm52184
Here's a link that may help to find out what model it is.
por
It is a bf9WM
por
Exibir mais 2 comentários
Adicionar a sua resposta
Jonathan. M será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 21
Ao todo: 533
