Ir para o conteúdo principal
Screen replacement - iPhone 12 MINI with OLED display
My screen is not working. I wanted to buy the replacement from ifixit. But you only have the LCD in stock. IF I change it with LCD, will it work?
I just want to be able to turn on my iCloud on the device so data can be recovered. Right now I cant do anything as the screen is not working.
If I get the LCD, will it temporarily work? As i said, I only need to screen to work for a short term so I can start the backup.
What other screen can i use to replace my current one? What are my options. Buying OLED would be too expensive. Please let me know if you have any suggestions
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
this isnt the actual store and only a help forum, yes an lcd will work and will function as normal, the only difference is you wont have truetone, you will have a warning that the screen might not be genuine and the battery will be used slightly more with an lcd
Esta resposta foi útil?
Pontuação 1
If it's just to get your data then buy a cheap screen. Hook it up and get your data off it. Don't see the point in spending hundreds just to get data.
Pontuação 1
Adicionar a sua resposta
ROK será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 567
