Ir para o conteúdo principal
The third-generation Golf (Mk3) made its home-market début in August 1991 and again grew slightly in comparison with its immediate predecessor, while its wheelbase remained unchanged.
11 Perguntas Visualizar todos
Why is my crankshaft not turning?
When I'm trying to set timing after changing timing belt and crankshaft pulley my crankshaft is stuck, it doesn't want to turn.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@qsquaredat double check your work with the belt replacement. Concern I have that this is an interference engine and your pistons may just hit the valves and thus "blocking" your crankshaft.
What year, what engine size and why did you replace the timing belt?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
QSquared@ será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 47
