Ir para o conteúdo principal
Guias e instruções de reparo para o MacBook Air totalmente redesenhado com Apple Silicon de segunda geração e tela Liquid Retina de 13,6". Foi lançado pela primeira vez em 15 de julho de 2022. Modelo A2681
20 Perguntas Visualizar todos
USB-C Thunderbolt does not work after spilled liquid
Hello everyone!
I have a MacBook Air M2 A2681 that got wet, after drying it the best i could, the thunderbolt ports have stopped working. How can I know if only the ports have been damaged or is it something on the motherboard? here on my country it is not easy to get a new port but i will try to get one to test.
I was able to remove them and tried to clean up with isopropyl alcohol
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
You can probably tell just by looking if it’s the port. Try looking with a flashlight and see if you spot any corrosion. Otherwise, you’ll want to open the machine up and see if there are any signs of liquid inside. You can remove the ports pretty easily and just see what they look like. If there’s corrosion on them, but internals look clean, probably just the port. You might even get it to work if you clean up corrosion with some isopropyl alcohol and a cotton swab. Depends on what the actual issue is. Liquid damage in the port can cause electrical damage to board components, but I have seen lots of these that are just the port itself.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks for the quick response. i will open again and try to take better pictures
por
Adicionar a sua resposta
Victor Adrian Toledo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 18
Duração total: 683
