Ir para o conteúdo principal
My PC runs but my screen is blank with blinking caps on. How to fix it
When I start my PC, it is running but the screen shows blank. The caps give 5 slow and 3 fast blinks, which I found related to motherboard or BIOS issues. How to fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @sakriyakar36264
As you said, a 5:3 error code indicates that the embedded controller cannot reach the BIOS within the established time limit.
The BIOS may have become corrupted. Try a power refresh and check if that resolves the problem.
Here’s the procedure:
a). Disconnect the charger from the laptop if connected.
b). Disconnect the main battery from the motherboard.
Here’s the maintenance and service guide, for the laptop series (you didn't specify the actual model but it should be relevant). Go to p.45 to view the procedure to remove the battery.
c). Press and hold the laptop's Power button for a full 30 seconds and then release it.
d). Reverse the above from Step b). to re-assemble the laptop.
e.) When the laptop is completely re-assembled, connect the charger and try to turn on the laptop.
If it starts OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been completely reset back to its default settings. Once the date and time have been adjusted the message won’t appear the next time that the laptop is started.
If you had previously changed any user defined settings in BIOS to suit whatever specific hardware configuration that you had for the laptop, then these will have to be set again.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Sakriya Karmacharya será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 57
