Ir para o conteúdo principal
Um roçador de eixo reto de 4 tempos fabricado pela Troy-Bilt. Este modelo é identificado como TB675 EC.
Line nipple on body.
I have a 3rd line nipple, straight, but NOT on carburetor, on body close to shaft. Anyone know the purpose of this nipple? How about where the line needs to go? FYI....only a two pole primer bulb, and, my trimmer has a choke.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I believe this is a grease fitting to lube the drive shaft bearings. As you hadn’t posted an image that’s my best guess.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Post a picture... now why didn't I think of that?!!!
Grease fitting is a great try, but a no cigar.
This is definitely a fitting that's made for a fuel line... I just don't know why? I'll get a pic loaded up later today, let you have a look at it. Might jar something at that point.
por
Adicionar a sua resposta
DMM needs to Trim. será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Ao todo: 319
