Ir para o conteúdo principal
Screen burn still present after screen replacement
I attempted to repair a iPhone 5 I bought. The phone had a screen burn as the seller claimed. After opening it, I noticed some corrosion and some rust. I cleaned it by some Alcohol and cotton swabs. I placed a good genuine screen I Salvaged from another iPhone 5 but the screen burn is still present. Is it because I didn't fully clean the corrosion in the connectors or it's a logic board issue?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
If the screen burn is in the same spot, updating or restoring the phone should fix the problem.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Angel Valencia será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 282
