noise coming from back
after changing rear shocks and link rod still have noise coming from left rear when brakes is applied . all brake pads was changed and serviced
Esta é uma boa pergunta?
Thanks but I found the problem to be the back seat locking mechanism and also a rod with bushing and ball joint was bad even when it was taken off it did not appear to be bad . I have no noise anymore.
Esta resposta foi útil?
Brake Caliper might need to be looked at, seal might be defective
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 53
Ao todo: 899
1 comentário
maybe one of the pads was installed backwards and you have metal to metal contact.
por CRD Compartilhar
