Why does my heating shield make noise
It makes a rattle noise from heating shield , every time I accelerate car
Esta é uma boa pergunta?
One or more fasteners are loose or missing. Another possibility is the heat shield is bent reducing the clearance require to prevent a rattle. this should be a quick and easy repair that will cost you less than $100. A third possibility is a broken exhaust hanger that allows the exhaust system to move far enough to contact the heat shield. One more possibility is a broken or wore out engine mount. If engine movement is excessive that may allow the exhaust to contact the heat shield.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 471
Be more specific, what Fit what specs what noise.
por Tom Chai
