Ir para o conteúdo principal
The 5th generation of the Moto E Play smartphones, released in July 2018. Model numbers XT1921
How can I replace the headphone socket?
in the past I damaged my headphone socket, now it has poor connection or no sound. or just straight up ignore it the headphone socket.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@fredrezones45 since iFixit does not yet have a guide for this, use something like this video to replace the jack. Once you remove the circuit board, you can then remove the headphone jack. Replacements are available at places like this and many others. Or if you are more of a reader, you may want to check this out Moto E5 Play
While you work on your headphone jack, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
FredReZones45 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 47
