Able to replace AC Inlet?
I am trying to see if it is possible to replace the AC let outlet on this iMac
Esta é uma boa pergunta?
It is technically possible, but there are no guides for the procedure online and it is probably not worth the work required to do the repair. It would be easier and probably just as affordable to purchase a used shell with a good condition power outlet and swap the logic board, power supply, hard drive, speakers, display, etc. over into it. You can find guides for removing the various other components here on iFixit. Good luck!
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 271
