Ir para o conteúdo principal
A Kia apresentou a segunda geração (JB) no início do ano modelo de 2005 na Europa e no ano modelo de 2006 na América do Norte, baseada em uma plataforma redesenhada compartilhada com o Hyundai Accent.
Power stearing fluid change
How do i fix my kia when stearing wheel makes much nois when turning. Should i drain the old fluid
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
@josephchidiadia I am honest with you, I have owned a multitude of vehicles in various state of repair ;-) and never had to change steering fluid. If it makes a noise when you turn your steering wheel, it is most commonly the steering pump (yes, replaced a few of those). The number one reason for that is not having enough power steering fluid in the small reservoir. Always check that first.
If that checks out, then there is the possibility of having an internal leak. That causes the noise by increasing the pressures on the pump. That would warrant a pump replacement. Make sure that the whine comes from the pump and not from the steering rack.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I have refilled the reservoir with but there was som old fluid in there. Is is going to help if i pump the old fluid out an replaced it new fluid.
por
@josephchidiadia Probably not but you can always try. At least that way it is going to give you peace of mind :-)
por
Adicionar a sua resposta
Joseph Chidiadia será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 38
Ao todo: 1,212
