Ir para o conteúdo principal
O smartwatch de quinta geração da Apple, com conectividade celular opcional, lançado em 20 de setembro de 2019.
Best Non OEM Replacement Screen?
Subject is an Apple Series 5, 40 MM watch with a cracked screen. I can still see the icons.
Do I need anything more than a replacement screen kit to fix this?
There are multiple screen kits available ranging from $10 to over $200. Which is the best bang for the buck. It doesn't make sense to buy a $139 screen kit for a watch that old.
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
you should link the one you're interested in so we can take a look at it.
por Compartilhar
Looking at this one Apple 5-40mm
por Compartilhar
@stanleybunch this isn't a full display, its only the digitizer and front glass, so if you have LCD problems, or problems with the backlight, this won't fix it unfortunately :(
por Compartilhar
Adicionar um comentário
2 respostas
@stanleybunch - That link is only the crystal/digitizer part it’s not the OLED panel part which is glued to the crystal/digitizer part. That’s why it’s so cheap (note they called it an LCD which it’s not)
I really don’t recommend attempting ungluing the OLED as more often than not you just end up killing it. It’s better to get the full assembly.
Esta resposta foi útil?
Pontuação 0
Buy a complete screen assembly, they aren't cheap. If you don't want to spend a lot then I'd bang it on ebay as spares or repairs and let someone else have a go. OR, look on ebay for the same watch locked to icloud and use the screen off it.
Pontuação 0
Adicionar a sua resposta
Stanley Bunch será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 48
Ao todo: 902
