Ir para o conteúdo principal
Repair information and guides for the 2015 12" Retina MacBook Model A1534
Horizontal screen distortions, display?
Hi Dan,
I have one of these in for repair with horizontal distortions. Would that indicate a ribbon cable problem? When i tilt the lid in a specific angle it gives me a perfect display. Thanks in advance
Update (05/14/23)
These are a bit dark..
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Can you post a picture so we can see what you see.
por
I did sent some pictures, thanks!
por
Adicionar um comentário
1 resposta
Solução escolhida
While tilting the lid alters the screens reaction this is not a cable issue, it’s a bonding issue of the cable to the displays LCD panel. Sadly this is repairable issue, it will require a new display assembly to fix.
Here’s the guide Retina MacBook 2015 Display Assembly Replacement
These displays are getting hard to find, you may need to search for a used broken system to get it.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks for your reply. That's a pitty.. So I better not open it up to replace the ribbon if that's useless. Thanks for your kind help!
por
Adicionar a sua resposta
Egbert Kappert será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 32
Ao todo: 229
