Ir para o conteúdo principal
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
20 Perguntas Visualizar todos
No signal displayed on TV
I have an Xbox one s that shows no signal on the tv. I have the following voltages on the pins
1,1.39v
2, 0v
3, 1.36
4,1.44v
5,0v
6,1.54v
7,1.57v
8,0v
9,0.75
10, 1.36v
11, 0v
12,1.18v
13, 4.24v
14, 0v
15,6.01v
16,6.01v
17 0v
18,6.05v
19,0v
I believe there should be a voltage on pin 19, can anyone confirm if the remainder of the readings are normal. Does this point towards a faulty retimer chip?
Thanks Liam
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Thanks,
I will give it a try.
Thanks Liam
por
Adicionar um comentário
1 resposta
just install another hdmi port
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Liamc será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 47
