Ir para o conteúdo principal
Processador dual core Intel Core i5 de 2,6 GHz (Turbo Boost de até 3,2 GHz) com 3 MB de cache L3 compartilhado. Lançado em 13 de fevereiro de 2013.
New screen camera not working
I swapped a screen from a Macbook Pro A2251 and installed it in a MacBook Pro A1708, the screen works as expected but the camera isn't working saying camera not detected in all applications. I have checked all the connections and reseated them. Should this setup work and what connection is for the camera?
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
@jasonmullan - Where did you purchase it?
por
I got it from a friends busted machine
por
Adicionar um comentário
1 resposta
A2251 refers to a MacBook Pro (13-inch, 2020, Four Thunderbolt 3 ports), and A1708 refers to either the MacBook Pro (13-inch, 2016, Two Thunderbolt 3 Ports) or the MacBook Pro (13-inch, 2017, Two Thunderbolt 3 Ports). The display from the 2020 MBP is not fully compatible with the 2016 and 2017 models. Although the display portion will function, the camera will not. In order to have a working camera you will need to install a fully compatible display. Check this page for further information.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jason Mullan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 410
