Ir para o conteúdo principal
O "tablefone" topo de linha de décima geração da Samsung, com caneta S Pen e capacidade 5G. Lançado em agosto de 2019.
Overheating Error Glitch with Note 10
It is not actually over heating rather I assume bad sensor somewhere. I have successfully pulled the back off the device but cannot pin point the faulty hardware. Some help would be appreciated, thanks in advance
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi there! This could either be a faulty charging port or a faulty wireless charging coil as both have built-in thermal sensors! It's very unlikely, but if neither of these fix it then it may be a logic board issue. Hope this helps @beefman26 !
Esta resposta foi útil?
Pontuação 1
2 comentários:
Sorry I didn’t get a notification of your answer. It also doesn’t charge wirelessly. I just tried a new charging coil with no luck. Is there anything else I can try? Thanks
por
@beefman26 Could be the charging port, if i remember correctly there's a thermal sensor on there too! If not, a battery might be another good shot
por
Adicionar a sua resposta
Ethan Lewis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 47
Ao todo: 1,074
