Ir para o conteúdo principal
Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
20 Perguntas Visualizar todos
A.O. Smith water heater
Water heater makes a bubbling sound when reheating water in the tank
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Have you checked the operating instructions? Check your model at https://www.waterheatermanuals.com/ao-sm... and go to the troubleshooting sections to find the possible cause. Sometimes this is normal operation of the water heater, but it all depends on your model.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @d2icsw2fhjpsdob,
What is the model number of the water heater?
Sounds a though the thermostat may be faulty and not turning off the power to the heater when the water temperature has reached its upper limit or cut off point.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
heatherw319 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 96
