Ir para o conteúdo principal
Disc will not read
My xbox 360 will read rock band which is severely scratched and will not read dead island which looks very good
Update (04/24/23)
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@tydinbrandt could be an issue with the laser. I would suggest to clean that first. Anything after that would require a replacement. Eiterh of teh complete optical drive Xbox 360 Optical Drive Replacement REMBMER that "the DVD drive works only with the particular game console it is installed in" it's still possible but will require a bit of work. OR you can try to replace the laser assembly. Great guide for that can be found on here
Of course, you could also elect to just continue to play rock band and skip dead island altogether ;)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Tydin Brandt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 96
