Ir para o conteúdo principal
A 10 speed mixer made by KitchenAid in 2006.
28 Perguntas Visualizar todos
Can I bypass the control board to test the motor?
I bought a used mixer that isn't running and would like to test the motor before I invest in a new control board. Is it possible to temporarily bypass the control board to test the motor? I have already ruled out a short in the power cord.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@eraskin yes it is. Use thios guide KitchenAid Professional 600 Drive Motor Replacement and disconnect the motor controller from the motor. Then apply power directly to the motor. How you accomplish that, will depend on what you have available. I would use test leads with alligator clips, and come of the main power supply from the mixer. Of course, you can also just take a stripped power cable and use that :-) Whatever you got .... It'll buck since it will get a full load so make sure everything is clear in the transmission etc.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Evan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 121
