Ir para o conteúdo principal
Samsung's third iteration of the Galaxy Watch with a newly integrated BioActive Sensor. It was released August 27th, 2021. Model SM-R860, 40 mm, non-LTE version.
19 Perguntas Visualizar todos
Can the battery be replase with longer lasting one
Can the battery be replase with a longer lasting one
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@kennethmil87767 there really are no larger capacity batteries for those. You may find some advertised but reality is, that you can only "squeeze" so much storage into that size of battery. If you find that the performance of your watch has decreased, and the battery just does not seem to last as long, check all of your settings and minimize others "apps" and uses. After that, you may need to consider a new battery, but there won't be much difference between a standard one and "high-capacity" advertised batteries (other than price).
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kenneth Miller será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 54
