Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
1199 Perguntas Visualizar todos
How could I save an iCloud locked iPhone X?
I buy and refurbish phones to then sell them on. I recently bought an iPhone X without reading the description properly. The phone ended up being iCloud locked.
I currently have a seperate iPhone X which I am not prepared to sell because of a bad screen replacement. I am wondering if I could transfer some of the parts from there into this iCloud locked phone.
I read that the motherboard and the Face ID sensors are paired. I thought I could therefore transfer both of these into the iCloud locked phone.
Would this fix the iCloud lock? If not are there any further parts that I could transfer as well to fix the situation?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Pergunta mais útil
Hi GOPnz,
On the iPhone X there are three assemblies that need to be transferred in order to keep the Face ID functionality. You'll need the logic board, the earpiece speaker assembly from the display and the front camera assembly. I wrote a guide specifically for your situation where the object is to replace the required components in order to have Face ID.
iPhone X Face ID Replacement - iFixit Repair Guide
The only other thing to note if you want a fully functional phone is that you'll need to retrieve the MtSN number from either the old screen or the logic board and program it into the replacement if you want to keep the True Tone function. A JC or Qian Li or similar device programmer is needed.
With regard to the iCloud lock, that's specific to the logic board so once you've replaced the logic board you're working on a whole new phone with a different IMEI, MAC address, etc., so the old iCloud lock is no longer a concern. Bringing along the other parts will preserve the Face ID functionality but has no effect on the iCloud lock.
Esta resposta foi útil?
Pontuação 3
icloud is locked to the logic board only, yes face id is paired so you will need an icloud free logic board with the paired camera
Pontuação 1
Sounds like it would be easer to just move the display over than the logic board.
Pontuação 0
you will need to contact the previous owner and have them login to the icloud account and remove the association, either on the phone itself, or via either www.icloud.com or appleid.apple.com.
beyond that there is no permanent solution.
yes, you will find services and software offering to remove icloud accounts, it's all BS. these "solutions" involve jailbreaking the phone then installing a "bypass". but the phone will not behave like a normal phone (if i'm misstating some of these items, i welcome correction as a am not a jailbreaking expert). you will likely have issues with downloading and installing apps, you may have issues trying to use the only on you cellular service account, you cannot do auto upgrades the IOS, your device becomes more vulnerable to malware/hacking, battery drain/usage increases dramatically, it makes the overall IOS environment less stable meaning more crashes, and if you do upgrade the IOS or reset the phone, you have to re-jailbreak it again.
using jailbreaking to "fix" an icloud account is like (you may be too young to actually relate to this) watching TV before they had remote controls. you want to change the channel or change the volume or adjust the rabbit ears, you had to get out out of your chair, walk to the tv and do so manually - every time. sure it all worked, but it was horribly inconvenient compared to what a modern day TV remote can do for you.
if anyone has a better analogy, i welcome input on that regard as well. :)
bottom line, the only way to properly remove it is to have the icloud account owner do it
Pontuação 0
Adicionar a sua resposta
GOPnz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 100
