Ir para o conteúdo principal
The Motorola Droid 2 (A955) is the fifth phone in Verizon's Droid line.
13 Perguntas Visualizar todos
T. 5.5 Torx striped
I ordered your large fixit kit with all the torx and such but when following exact directions in removing the 5.5 Torx screws from this droid 2 (Global) they started to strip the 5 is way to small to start I went to a 6 torx and was able to remove three.. Any hints to remove these other stripped screws? I am about to just drill them out.
Esta pergunta é pertinente?
Pontuação -1
Adicionar um comentário
1 Resposta
Solução escolhida
Check out the answer here for some suggestions on stripped screw removal. If you go the route of power tools just be sure to be careful and steady so you don't damage any surrounding components. Good luck and I hope this helps.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
John McGrath será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 892
