Dryer series 3000.will not start so I changed the thermal fuse
Why do I keep blowing thermal fuse. I have cleaned all the duct work. Do you think the thermistor sensor needs to be replaced?
Esta é uma boa pergunta?
@josephvercherjr if your duct work is truly clean and you check the rest of it, I would check/replace the cycling thermostat. Of course, you need to check the heating element and make sure it is not shortened to ground. Instead of going to just replace things, lets try and diagnose your dryer. Let us know what the exact model is and what you have checked.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 72
