Ir para o conteúdo principal
The Toshiba Satellite C655-S5049 is a laptop that was released around 2010-2011. It allowed people to do basic computing tasks and was at offered at an affordable price for consumers.
1 Perguntas Visualizar todos
I keeping Error Code: F3-F200-002
Hello So I A Toshiba Satellite C655-S5049 And I Rest The Hard drive in recovery Then after that I want Back to recovery mode then I saw this error Code that say F3-F200-002 I turn it on and off go to windows load file get the error code again use a usb to reinstall it Did not work took me back I everything that a can So If you know About This Error Can you Help Me Fix This Thank You
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
What version of Windows are you using?
In some cases this is a memory error. Try reseating RAM modules.
Apparently could also be a hard disk corruption error. If you don't aleady have an SSD I suggest getting one.
Esta resposta foi útil?
Pontuação 1
1 comentário:
So For Long Wait It Is Windows 7 Home premium
por
Adicionar a sua resposta
MrGuy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 120
