Ir para o conteúdo principal
Guias de reparo e suporte para máquinas de café Nespresso Inissia.
Water not pumping through.
My machine is new but was in storage for a year. It switches on and I can hear the pump but water does not pump through the machine.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Either some hoses are clogged by scale.
Or a hose may have come off from its connector.
Does the water level in the tank decrease?
Does water leak out anywhere from the machine?
Esta resposta foi útil?
Pontuação 1
I am pretty sure that there is air in the hose. Either you have to open the machine and disconnect the hose from the pump, so the water can fill it. Or you can use these instructions.(In spanish)
Or: fill the Reservoir with water and lift it up several (Up to 30 times) times and put it back on again.
Pontuação 1
Adicionar a sua resposta
Idris Nomani será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 15
Últimos 30 dias: 78
Ao todo: 1,991
