Ir para o conteúdo principal
Um dos modelos de 13,3" da linha de laptops 13A multi-flip da Sony.
Black screen fix possible?
This VAIO shows nothing on the screen. It works fine (including the touch panel) with an external monitor.
There's no faint picture either, so it's not just a backlight issue.
The screen connector shows no damage or corrosion.
Is it possible to isolate the problem on the screen's side or the mainboard?
Update (04/11/23)
A new screen is not available for purchase and it would probably also be prohibitely expensive to buy one. It would be cheaper to find another used laptop with a working screen.
I disaseembled the screen as per the instructions to see if there is an obvious fault, but all connectors looked fine and there was no corrosion or burned parts. The test points on the PCB measured the correct 5V. I suppose it's possible that there's a bad connection in one of the ribbon cables.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
If it has a HDMI then connect it to you tv or a screen?
por
Yes it does.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
you should get a new screen to test if its the board or screen at fault.
i don't think it would be a board issue as its connecting to the monitor, but this would be telltale sign if it was a screen or board issue
https://www.amazon.com/KREPLACEMENT-Repl...
Substituição da tela do Sony Vaio Fit 13A SVF13NA1EL
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
naujoks será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 504
