How can I change the water pump?
The water pump needs to be changed. What would be the best method of doing this?
Esta é uma boa pergunta?
@mahdirahim61663 this should work for you
Removal and Installation
Loosen the drain plug, and then drain the engine coolant. Remove the radiator cap to drain with speed.
Remove the drive belt (A) after turning the drive belt tensioner (B) counterclockwise.
Remove the water pump pulley (A).
Remove the water pump (A) with the gasket.
ULEV : Remove the exhaust manifold heat protector (A).
SULEV : Using the SST (09392-2H100) (A), remove the front oxygen sensor (B) and the remove the exhaust manifold heat protector (C).
Remove the water pump housing (A) with the gasket and the water inlet pipe (B).
Installation is reverse order of removal with a new water pump gasket.
Fill the engine coolant.
Start the engine and check for leaks.
Recheck the coolant level.
from here
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 41
Duração total: 677
@mahdirahim61663 what exact year and engine size is it?
por oldturkey03
They there, I edited your question a little bit just to be a bit more accurate to what I believe you are asking. Can I ask what specifically is wrong with your car's water pump?
por Jacob Mehnert
