Ir para o conteúdo principal
O XMAX V3 Pro é um vaporizador portátil para ervas secas da marca TopGreen.
How to repair heat sensor error?
The vape does not heat up, it always displays the heat sensor error.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
You can try to remove the battery and put it back in, that has fixed the sensor error for some users. If that doesn't fix it you might have to reach out to the manufacturer. I'm pretty sure the warranty is 12 months from purchase.
Esta resposta foi útil?
Pontuação 0
Hitting and smoking not working
Pontuação 0
1 comentário:
Not sure but could be something wrong with the contacts or temperature probe
por
The other Day i had the sensor error.
It happened when I was outside at night, not freezing but it was pretty chill.
After carrying it a few minutes in my hand, with a few times turning it on, it worked again.
Today I found a statement from somebody claiming to be representing XMAX at the fuckcombustion forums.
This behavior is no bug or malfunction, but a security feature.
18650 Batteries don't perform well, when too cold.
You just need to warm the device a bit and it works as supposed.
Pontuação 0
1 comentário:
Today the error happened again, while indoor and it couldn't be the "too cold" protection.
I took the Device apart, for the Coil, the Thermistor and the + Wire you need to solder.
In the actual heating chamber is a mesh-coil and one of the contacts just barely touched the mesh.
I have not put it back together yet, its really finicky and takes a while to fiddle the wires through the different holes.
In this picture you see the bottom of the heater with the 4 wires.
The two thicker wires with translucent insulation are from the Coil
https://guide-images.cdn.ifixit.com/igi/...
por
Adicionar a sua resposta
[ Bor ] será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 30
Últimos 30 dias: 105
Ao todo: 4,621
