Engine stalls when brake released
Toro z master z400
My engine stalls when brake released. Checked both brake and seat safety switch and they tested ok. Any ideas would be appreciated.
Esta é uma boa pergunta?
Toro z master z400
@uwl8vzazgdhdqgd check the shutoff cables and all the wiring. You have mentioned that you already checked the seat and brake switch, so next would be the delay module and the kill relay. Those errors are easy really simple, like stretched cables etc. Or a bear to determine where the wiring is faulty. Here is the SM for your Mower Toro Z Master Z400 SM and you will find the wiring diagram in the back of it. Around page 155 is where I would start.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 224
