Ir para o conteúdo principal
Lançado em novembro de 2020, o MacBook Pro de 13" traz o SoC M1 da Apple baseado em Arm, com CPU de 8 núcleos e GPU de 8 núcleos. (Modelo A2338 / EMC 3578 com duas portas Thunderbolt 3)
Service Recommended: MacBook Pro m1
Hello! I just changed the battery of my macbook pro m1 and I get that error. I have restored the MacBook and nothing. The battery seems to work since without the power cable it works fine, however I can't see the percentage and I get that error. Can somebody help me?
Imagem
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Where did you get the battery? Also are you sure you needed to replace it? This is a young system which shouldn’t need a new battery yet.
por
Adicionar um comentário
1 resposta
When you go to System Settings -> Battery, what do you see? Can you see the percentage there? If so, you should let the battery charge to around 100%, then let it discharge to around 10% or so, then reconnect the charger and let it charge up again to 100% to see if the message goes away after putting the battery through a full charge cycle. You could also try booting into Safe Mode to see if this fixes the issue. In the worst case scenario, there may be a defect with the battery you installed. Good luck!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Borja 1 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 467
