My Screen tv is broken
Good day kindly advise if you can fix my sony bravia screen it is broken
Esta é uma boa pergunta?
@maandaanga "if you can fix my sony bravia screen" sorry, but iFixit does not do repairs. A broken (damaged) screen can not be repaired but commonly needs to be replaced. Remove the back cover from your TV and check the label that is glued on the back of the screen module. Use those numbers to see if you can find a replacement LCD (screen) assembly. Some of those screens (including shipping and handling) can cost more than a new TV.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 262
@maandaanga Let us know how do you know that the screen is broken. Did it have physical damage? Is it cracked etc?
por oldturkey03
