What can I substitute to charge this with
I lost the original device charger it's DC15v input/3.2A & 12 v output & looks like says 5.? Not sure can't read it then like 13.1A what can I use to charge this with as a substitute and how much higher is safe for the device n how much lower is enough to do so
Esta é uma boa pergunta?
2 comentários
Hi @elizabethlalone,
What is the make and model number of the jump starter?
Presumably you're looking for the adapter that charges the battery in the jump starter, is this correct?
It's unusual to have a step down DC adapter to charge a battery. Normally an AC/DC adapter is used.
Just curious how you know the specifications of the adapter if you lost it? ;-)
por jayeff
Because it gives this information on the device itself still not just the actual power cord ware you plug the cord into the power port when charging it and under that says out poot and a sticker on the back as well but it's not a jump box it's a go power plus portable power station or emergency weather power box is what it's for. Has emergency weather radio stations and flash light phone fast charge ports and the .3.0 as well and aac output plug as well I live in a RV in bfe lol no electric no running water but has a artisan well less than half mile from my camp that pumps out fresh spring water 700 gals an hr or something like that but to be able to have access to charge phones and post
por Elizabeth Lalone
