My laptop is just lighting the power light but no display or keyboard
My laptop is just lighting the power light but no display or keyboard is lighting
Esta é uma boa pergunta?
Hi @markoesibz
Try a power refresh and check if that resolves the problem.
(click on image)
If it starts OK then there may be a message stating that the date and time are incorrect. This is normal as the BIOS has been reset. Once the date and time have been corrected the message won't appear the next time that the laptop is started.
Esta resposta foi útil?
Well for Keyboard backlighting issues can be caused by a range of factors, one of them being the driver not being updated. Keep your drivers updated to avoid this issue. And there is no display, then that means that the system is getting powered up, but the GPU might having problems, your internal disk drive is corrupted or damaged, your display is damaged, or LVDS cable might be loose.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 80
