Ir para o conteúdo principal
Guias e instruções de reparo para o MacBook Air totalmente redesenhado com Apple Silicon de segunda geração e tela Liquid Retina de 13,6". Foi lançado pela primeira vez em 15 de julho de 2022. Modelo A2681
How to properly disassemble the keyboard area and clean it?
I want to clean some dust off the keyboards on my Macbook M2 Air. I have cleaned the top of the keycaps but some dust might have gotten beneath in and between the small gaps. Is it possible to safely disable the motherboard and the keyboard area so that I can dust the keys?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The keyboard is riveted to the uppercase and getting to it from the inside is quite difficult. Since you have such a new system I would leave things alone. Dust is mostly not the worry, liquids are! Clearly don’t use your system on the beach of eat food which is crumbly as this type of debris can also cause harm.
If you haven’t I would sign up for AppleCare+ That will give you a bit more protection if you are likely planning to go into a war zone or just have messy kids😎
Only use a lightly dampen clean towel with mild counter cleaner on the shell and keyboard surfaces, and for the screen straight water (distilled being best) on a lightly dampen clean towel and if the dirt is stubborn, add a little White Vinegar.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Tatasky HD será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 30
Ao todo: 652
