Ir para o conteúdo principal
Apple's mainstream 2021 iPhone was released on September 24th and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 12.
20 Perguntas Visualizar todos
Wifi Greyed out and bluetooth
Hello, I got this phone in repair today it had already had the screen replaced on it before working on it the screen was an Aftermarket LCD not OLED I am thinking that the screen shorted out the board causing the wifi not to work anymore. Anyways I tried a new antenna and still greyed out anyone fixes this issue or know what I should do next or is it SOL?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
is the WIFI not working since it crashed? If so, it could be a problem with the motherboard. You have to separate the motherboard first. maybe the pin is disconnected
Esta resposta foi útil?
Pontuação 0
Check it’s on the latest update. Also if there is a security app on the phone remove it. I had a phone in with the same issue. They had some security app that had disabled the connections, when I removed it all the connections came back on straight away. If it needs updated you’ll need to hook it up to a computer.
Pontuação 0
1 comentário:
The phone has been factory reset
por
Most likely cracked or torn pads on the interposer board or the Wi-Fi IC. You will need to separate the boards and check the pads between the boards before taking diode measurements of the Wi-Fi IC.
Pontuação 0
Adicionar a sua resposta
Mark D Schlossman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 34
Duração total: 2,659
