Ir para o conteúdo principal
Informações de reparo e suporte para cortadores de grama com operador a pé fabricados pela Toro Company.
Front wheels not straight
On the toro 30” time master are the wheels supposed to look as they are leaning outwards and not straight? We haven’t even used ours yet , unloaded it yesterday and just want to make sure the front wheels are right before using it. Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Since it is new, it is possible that the bolts holding the wheels in are loose. In the center of the wheels, there should be a screw or bolt that needs to be tightened. If there is no bolt visible, look closer, as there may be a cover to keep grass out.
It is worth noting that I don’t have this exact model lawnmower, but most are pretty similar in design, so please take this with a grain of salt.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Will definitely check that, thanks
por
Adicionar a sua resposta
Amanda Chandler será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Ao todo: 425
