Is there a fuse there?
Where is located the fuse and how can I approach it?
Esta é uma boa pergunta?
Try the following methods to restore power to the Brother machine:
If you still cannot power the machine on, then you likely have a bad power supply which can be purchased here...
https://www.ebay.com/itm/321986636857
Esta resposta foi útil?
No, it did not help, (BTW, how can the paper tray position affect the power?) The problem may be in the power supply. Is there a procedure description how to replace it?
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 37
Ao todo: 1,137
There are numerous fuses. Can you describe the symptoms?
por Jim Compartilhar
The printer does not show any sign of life after an unclear power interruption.
por tvarozna Compartilhar
