Ir para o conteúdo principal
2,26 ou 2,4 GHz / Estrutura monobloco de plástico branco
Need to remove the battery
My wife's MacBook, circa early 2011 needs to be scrapped out. An electronics scrap drive is scheduled next month for my community, but I believe they will only accept this unit if it has no battery in it. I opened the back but to remove the battery, I will need a tri wing screwdriver like you sell. Not sure I need a Y0 or Y1 size. Do not need a new battery or anything else. Can you tell me what size I need?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
This is the needed tool Tri-point Y0 Screwdriver
Imagem de Similar to a Phillips, but with 3 blades. Precision fixed blade screwdriver engineered by iFixit.
Produto
$5.49
Esta resposta foi útil?
Pontuação 2
1 comentário:
Hi Dan, thanks for the message. I will buy this item from fixit, just like I bought the kit I used to replace the battery in my iPhone. Hope it works!
Dave
por
Adicionar a sua resposta
David Swanson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 32
Ao todo: 289
