Ir para o conteúdo principal
Repair manuals and information for the Microsoft Surface line of tablets.
How to remove wifi antennas?
I want to buy a new tablet where a technician can remove WiFi antenna. I am looking at:
  • Samsung Galaxy Tab S7 FE
  • Samsung Galaxy Tab S6 Lite
  • Microsoft Surface Go ...
  • any other tablet that's good for annotations/diagramming
Why? I got into medical school after lots of effort and a 1-year gap; now, my bad habits are catching up and I need to strike a balance - like my life depends on it.
My !!%@ addiction is under control, thanks to on-campus counseling, but I want to remove triggers and associate tablet to studying only.
In other words: make sure tablet can only be used for note-taking and reading (it is okay to use my desktop in my private room to do other stuff).
Also, once-a-week I'd like to sync notes and PDFs to my desktop and to cloud. I hope that's possible via USB cables.
Please advise whether, and which model, removal of WiFi antenna is possible.
______________
original question: Is is advisable to remove wifi antennas?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@timtomissus could you please chime in
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Why not instead just turn on the parental controls and have a consoler or friend/family set it up? What you are asking for is theoretically possible but but its like using a sledge hammer to nail in a screw. There is a better tool for your problem that can fix your issue as well as making it so you can actually sync your Tablet.
Given that you already admitted you have a problem getting rid of the antenna wont help you as I can think of 2 ways you can potentially circumvent you getting rid of the antenna and then you are back at square 1.
Answer: Use parental controls, onboard andrioid is good but there are other apps that can and will lock you out of nearly everything except at certain times, and what you specify.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Rogers J será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 237
