Meu celular caiu dentro d'água.
Ele não está ligando e a bateria inchou, por onde começar?
Esta é uma boa pergunta?
@deivinhoda54437 your phone is water damaged. For now you want to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your Xiaomi Poco M3 using something like [https://www.youtube.com/watch?v=bEfd0Gv... This one] or even this one as a guide . You must remove all EMI shields from the circuit board. If you do not remove those, you might as well not do anything. After you remove those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for an Apple iPhone 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://pt.ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@deivinhoda54437 o seu telefone está danificado por água. Por agora quer parar de continuar a tentar carregar, sincronizar ou utilizar o seu telefone de outra forma. Isto pode piorar ainda mais a situação, o que pode danificar ainda mais o seu telefone.
A próxima coisa a fazer é limpá-lo. Desmonte o seu Xiaomi Poco M3 usando algo como este vídeo ou mesmo este como guia . Deve remover todos os escudos de EMI da placa de circuito. Se não os remover, mais vale não fazer nada. Depois de os remover, limpar toda a placa, conectores e tudo com +90% de álcool isopropílico. Siga [guia|5825|este guia] , e mesmo assim foi escrito para um Apple iPhone 3G todos os pontos continuam a ser pertinentes ao seu telefone. Enquanto limpa a sua placa, verifique se há algum dano óbvio, como componentes queimados ou em falta, etc. Quando estiver devidamente limpo, deve substituir a bateria. Todos estes passos são para evitar falhas retardadas causadas pela corrosão. O melhor a fazer seria limpá-la com um produto de limpeza ultra-sónico, mas se não tiver acesso a um, isto irá pelo menos ajudar. Uma vez tudo isto feito, remonte o seu telefone e reavalie-o. Até que seja limpo, tudo será apenas um palpite. Mesmo com tudo isto, os danos causados pela água têm apenas uma pequena hipótese de serem totalmente reparados, mas pelo menos pode tentar.
Enquanto trabalha no seu telefone, tire muitas fotografias. Uma vez terminado, tire essas fotografias e crie um guia para o iFixit. Isso irá ajudar a próxima pessoa que tiver o mesmo problema que você. É fácil e divertido criar estes guias. https://pt.ifixit.com/Guide/new A comunidade iFixit irá apreciar isto.
Reparação é Guerra à Entropia!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 86
