Ir para o conteúdo principal
Com exceção da edição Tahoe Limited, o veículo foi redesenhado para o modelo do ano 2000 na nova plataforma GMT800, ainda compartilhada com as picapes e SUVs de grande porte.
Having a problem turning it on
I recently had my Denali stolen and the thieves manage to mess up my whole ignition really badly … now my key don’t fully turn all the way and the only way to turn it on is by hitting a relay on the fuse box is there any solution to my problem …?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Most likely one of three possibilities. Attached to the actually key switch are two small usually light green switches, one may have gotten broken moved etc during the theft.
2: that particular relay has sticky contactors inside and needs to be replaced.
3: inside the steering colum cover at the ignition switch and gear shifter there is a stop the prevents the key from being turned to the run position if the shifter is not completely in the park position. I could have gotten bent or mis aligned during the theft.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
El gallo chingon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Ao todo: 357
